I rebuilt the carb. because it was leaking fuel out of the gaskets and at bottom of carb. It use to idle down before, maybe not down to were it should have, but better than after rebuilding it.
I screwed in the Idle jet until it stopped, now I wonder if I should have NOT screwed it all the way. I opened the governor up and checked the tension of the spring, it was loose.
I can turn in the Idle screw all the way and no effect at all. I thought I purchased a quality kit.
Anyone have any idea's about this.
