530 fuel filler pipe repair question?
I have a leak where the filler pipe is attached to the gasoline tank. What is the best way to repair this? The tank is off the tractor.
Thanks.
It probably needs to be soldered. I had a gas tank repaired at the local radiator shop. They blew air through it while using a torch. At work they had to be steamed cleaned for 8 hours
and if wasn't soldered that day the tank needed to be steam cleaned for another hour before soldering.
Check with your local radiator shop. Hal
