Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: Adding a waterline heater
Bob
12-18-2013 09:16:47
Heated water rises, so that's why you are supposed to install it in such a way that the heated water will rise into the engine, rather than be wasted in the radiator.
It looks like the hose drops down ahead of your intended heater location, to the bottom of the radiator, so I believe installing the heater where you propose would work... the heated water would move to the block rather than the radiator.
That being said, why not use a block plug heater?
I just looked at my Zerostart catalog... their part # is 3100013.
Book says it installs in the right side of the block, with the element pointed down.
Wcoyote
12-19-2013 06:57:21
 Re: Adding a waterline heater in reply to Bob, 12-18-2013 09:16:47
Thanks,Bob, I'll look at the hose again.
I like your suggestion on the block heater. To answer your question, however. I feel much more qualified in cutting a rubber hose and inserting a coolant heater (I've cut a rubber hose before) than in popping out the freeze plug (which I've never done). But I'll definitely give that serious though-
dale in nw wa
01-01-2014 19:56:55
 Re: Adding a waterline heater in reply to Wcoyote, 12-19-2013 06:57:21
The heater that Del used is the only one that you can use. unless you have 5/8 heater hoses. Also when you install the heater they need to point in the correct direction. I haven't use one in years. dont get that cold here in WA state Dale
