Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Glasses fogging, dust mask
Hendrik
12-10-2013 02:58:49
193.30.192.187
While power sanding, wire brushing, grinding, etc., I tend to wear a dust mask (covering nose and mouth), my glasses, a full face mask and hearing protectors. Especially when cold, the dust mask causes my glasses to fog up badly.
I'd appreciate any tips and remedies.
Thanks.
[Reply]   [No Email]
JRSutton
12-15-2013 13:29:51
100.0.77.120
 Re: Glasses fogging, dust mask in reply to Hendrik, 12-10-2013 02:58:49
buy a respirator. They work much better anyways, and you can also use them when working with anything with dangerous fumes.
If not that, than go with the dust masks with the valve in the front as others have said.
[Reply]  [No Email]
36 coupe
12-10-2013 16:59:26
69.49.143.80
There are coatings you can put on eye glasses to stop fogging.I have 2 liquid types and there are wax types.I used them when I did saw sharpening.
[Reply]  [No Email]
Hendrik
12-11-2013 04:55:22
193.30.192.187
 Re: Glasses fogging, dust mask in reply to 36 coupe, 12-10-2013 16:59:26
Thanks for the tip. Will try these coatings. Hope it will also be effective in cold weather when the fogging is worst.
[Reply]  [No Email]
patsdeere
12-10-2013 11:37:38
12.201.129.146
They also make cheap dust masks with a exhaust valve in front. Really cuts down on hot air coming out around the nose (and thus into the glasses).
[Reply]  [No Email]
Hendrik
12-11-2013 04:52:08
193.30.192.187
 Re: Glasses fogging, dust mask in reply to patsdeere, 12-10-2013 11:37:38
Tried this type and only after tightening the straps the fogging was reduced some.
Thanks.
[Reply]  [No Email]
bjb in Tx from Ne
12-11-2013 14:07:22
147.1.234.165
 Re: Glasses fogging, dust mask in reply to Hendrik, 12-11-2013 04:52:08
The 3M ones with the valve work good with glasses IF you make sure you get the metal nose piece bent good around your nose. Also sometimes the valves will stick so make sure it is loose before you start working.
[Reply]  [No Email]
showcrop
12-10-2013 04:54:06
75.67.231.80
I was having the same problem with just protective glasses, I started wearing a respirator mask which of course seals to your face so that no vapor gets to the lenses.
[Reply]  [No Email]
Hendrik
12-11-2013 04:59:16
193.30.192.187
 Re: Glasses fogging, dust mask in reply to showcrop, 12-10-2013 04:54:06
Thanks for the suggestion.
If the coatings don't do the trick I'll invest in a respirator mask. I'll need one that does not interfere with my full face shield.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
