Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: 3 cyl diesel rebuild
showcrop
12-07-2013 07:15:48
my experience is that it depends mainly on the seals. Rope seals need all of that breaker bar, and you should turn it by hand until you feel that it has relaxed a little. A lip seal will turn much more easily. another thing that can make them turn hard is caps installed backwards.
mick in il.
12-07-2013 16:44:52
 Re: 3 cyl diesel rebuild in reply to showcrop, 12-07-2013 07:15:48
Not rope seals, cap are on correctly I matched the numbers
John Deere D
12-07-2013 09:05:51
Are the PUSHRODS INSTALLED? What was the bearing clearances(how was clearance checked)..within specs? what was the crankshaft thrust clearance.(how was clearance checked..within specs? What make of a 3 cylinder engine? what was placed on the bearing shells (lube) at installation? How many rings per piston? were cylinders well lubed before pistons installed? did pistons install into bores with out excessive force?
Bob...
