Anonymous-0
I hooked a new horn up to my 12 volt Gator and it sounds very soft (minimally audible). Did not use a relay. Came directly from an unused 30 amp plug exiting the fuse box. All grounds appear solidly secured. Does anyone know what might the problem be? thank you.
Most likely is that is is a bad new horn common now days to get bad parts from the get go
