I just bought this tractor and it was pretty rough when I got it. I got it home and took the hood off. I found most of the wiring disconnected and a gas tank rusted to hell. It did have an alternator on it so I assumed it was 12v already. I started looking on this forum to get some advice and knowledge of these tractors. I then ordered all of what I thought I would need to get her back up. After the initial tear down and clean up, I started installing the new parts. Points, condenser, cap, rotor, plugs, wires, cleaned and change everything in oil system, new carb and fuel tank, re-wired everything to a diagram I got from here, new ballast and ignition. I had an issue with points that came in kit so I went to napa and bought GOOD points and condenser. She fired right up. Oh, and installed new battery-almost forgot that. NOW, it won"t start unless my battery charger is hooked up to it-obviously not getting enough from the battery. I didn"t change the coil-assumed it was 12v, I have very little spark at the plugs-almost none-and that baffles me how it can start with almost NO spark-so little I can"t see it. Your thoughts, questions and advise will be appreciated.
