Ford 2000 weak PTO
My tractor is a 1974 Ford 2000 diesel, 4 speed with live PTO.
Problem is the PTO is getting weak. When bush hogging, high, thick grass will stop the cutter/shaft all together.
Could this be that the two stage clutch is going out?
Any ideas?
Thanks
first.
ford 4 speeds of that era do NOT have live pto.
they are single stage clutch and non live.
second. a 4spd with a Dual range selector stick ( twin stick ) is an 8 speed. that those are COMMON with a 2 stage clutch and live pto.
assuming clutch freeplay is correct.. and it is the pto slipping and not something inthe driveline like a torque limiter.. then yep.. time for a clutch job.
(quoted from post at 12:48:03 10/22/13) first.
ford 4 speeds of that era do NOT have live pto they are single stage clutch and non live............
I have a Ford 3000 4 speed. I second what soundguy said " No Live PTO on a 4 speed." Look at the clutch.
Andrew
