Hydralic lift on allis chalmers wd45
jhilton
New User
I have a 3pt on the back of my 51 allis chalmers wd 45. However, it wants to crawl up after I have put it in the down position. Do I need to adjust something or bleed the lines. If so where and how?
Your system is set for drawbar control and you need to adjust it to lift and hold mode. If it is still there the procedure is on the side of the battery box, its also in the manual. Too entailed to explain here.
