TractorLinks.com
Restoration & Repair Tips Board
Re: fuel problems
Dieseltech
10-07-2013 04:04:48
Injection pump may need repair, test by running with the 2 screw timing cover loose if pump is DB or JDB model. If it runs better the retainer ring is failing, causing higher housing pressure. Will cause low power or shutdown, and can force fuel past shaft seals into crankcase.
