Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: 900 series power steering cylinder
showcrop
10-03-2013 19:09:19
I had one leaking badly maybe 6-8 years ago. The problem with these is that you have to cut them open to renew the seal. Good hydraulic shops are equipped to do this but it is spendy. It was around $360.00 back then. They install a new length of chromed rod along with a new seal.
Rufus80
10-05-2013 12:11:43
 Re: 900 series power steering cylinder in reply to showcrop, 10-03-2013 19:09:19
You don't have to cut it apart to replace the rod seals. You only cut it apart to replace the shaft. There is a snap ring that holds in the seals.
showcrop
10-05-2013 13:52:32
 Re: 900 series power steering cylinder in reply to Rufus80, 10-05-2013 12:11:43
But 99.95 of the time if the seals are gone so is the chrome, right? Don't replace seals without inspecting the rod on the bottom at mid point. I have one that wasn't bad so I cleaned it up good, put a little JB weld on it then smoothed it good with some 1200 sandpaper and it has been good.
Rufus80
10-05-2013 15:31:02
 Re: 900 series power steering cylinder in reply to showcrop, 10-05-2013 13:52:32
I wouldn't say 99.5% of the time. Seals go out for lots of the reasons ie- age, oil contamination, shaft pitting/rust, etc. I work in the hydraulic repair business and see a few of these cylinders every year. I would say for most of them the seals are out just from age. I have one in the shop right now and yes the chrome is coming off the rod. The customer is not concerned ,and I can polish it smooth , because he only puts a few hours on it a year and is stored inside. Also the spot that is wore is inside the cylinder ,where it can't rust , when not in use.
showcrop
10-07-2013 06:01:23
 Re: 900 series power steering cylinder in reply to Rufus80, 10-05-2013 15:31:02
Rufus, I have three of these rowcrops. My experience and others that I have talked to is that the chrome wears off right at the center, so with a slight turn of the wheel the worn part is inside. You may want to advise your customers to turn the wheel a little to the direction that pulls it inside before shutting the tractor off.
