Just setup an Electrolysis Tank
Cjet
Picked up the tank about three years ago and finally decided to try it out. Started with a MM ZTU front wheel. Looks like its going to work. After the tank I pressure washed to clean the loose paint and crud off. Then a quick trip thru the blast cabinet and followed that with some Ospho.
ud
When I built my setup several years ago I was told to use
Tri-Sodium Phosphate(TSP)available at Home Depot as the cleaning compound. It is supposed to prevent flash rust.
(quoted from post at 21:06:22 10/02/13) When I built my setup several years ago I was told to use
Thanks, steamnjn23. I'll give it a try on the next batch.
I'm on my third restoration with electrolysis. Works great. It does all the work. Wire brush the electrodes occasionally for better cleaning. Looks good.
(quoted from post at 02:39:16 10/03/13) I'm on my third restoration with electrolysis. Works great. It does all the work. Wire brush the electrodes occasionally for better cleaning. Looks good.
I had noticed the amperage had dropped down to about 2-3 amps from about 8 to start with. I couldn't believe all of the crud stuck to the electrode metal when I checked it. I better check it more often.
(quoted from post at 17:09:22 10/03/13) Cjet, open your email and i'll send you links to various sites that dealt with electrolysis tanks
I think I got it open now.
