1953 Jubilee Hydraulic Port
Jimch
New User
What is the thread size (type) of the hydraulic test port under the brake pedal? It's about an inch or so from the bottom of the sump.Is an adapter available to run Hydraulics off of it? The fitting in there now has an allen wrench cap screw.
(quoted from post at 08:41:04 10/01/13) What is the thread size (type) of the hydraulic test port under the brake pedal? It's about an inch or so from the bottom of the sump.Is an adapter available to run Hydraulics off of it? The fitting in there now has an allen wrench cap screw.
im, I can't help you with size. I would just take it out & measure/compare, but my best guess is 1/2 NPT & next best would be 3/4 NPT. But I post, because I wonder if you realize that this will not be pump pressure of ~2000PSI at all times. Sometimes it is only about 40PSI due to unloading/bypass function.
