scott rollins
Well here is what I have, number one cyl at around 3/4 of the way to TDC , flywheel at 12 :00 , the X on the mag is seen thru the sight window, new plug wires in the correct order 1342, I primed the fuel pump , took the fuel line off the carb and didn't see any gas coming in, so I still need to figure that one out, I sprayed starting fluid into the carb, gave it a crank and it turned over but didn't start. Back to the drawing board I guess. I won't have anymore time to spend on it for about a week or so, just wanted to post an update. I'm wondering if not being all the way up to TDC has something to do with it? If I take it all the way I won't be at 12 I will be more like 2-3 o clock
