MF 135 Hydraulic Pump
Donando
New User
Hi
My 135 hydraulics are very slow & now will hardly left slasher of the ground.
I have checked filter and appears damaged, thus not filtering.
I am guessing some muck may have passed through the damaged filter into the pump.
Do I have to split the tractor to remove Pump ??
Any advice welcome
Install a pressure gauge and see what your pressure is. Hal
PS: Place your request over on the MH & MF forum as they will know if the tractor has to be split.
No need to split the tractor, but you do need to lift the top lid. Remember to reach in through the dipstick inspection cover and remove the little roller from between the control forks and remove the stack pipe from under the transfer plate on the front right of the cover before lifting the cover.
Sam
