Selector switch
I purchased a Jds666 light switch from Steiner and installed it into my ZAS Minnie Mo. I"m having trouble because it doesn"t operate like the original I removed. Please help.
P.S. What does TL, HL,& FL stand for?
Thanks for any help you can give!!
Martin
Thanks for the info!! On the old switch from left to right it went off, start, dim, bright, and lights only. On the new switch I hoped it would be the same but from left to right it goes off-ok,
start-engine cranks but doesn't fire up, dim- engine starts and lights bright, bright-engine starts and lights bright again, and last spot should be lights only and lights on and engine still running. I hope I didn't buy the wrong switch. Please help! Thanks
Check your wiring on the switch. Sounds like you have ignition and one of the light wires (headlights ?) reversed.
From switch diagram it appears it should operate:
1. Off
2. Ignition, no lights
3. Ignition, headlights and either rear flood light or red tail light
4. Same as 3 but flood light, red light reversed
5. Lights only
I believe this switch selects rear lights rather than dimming the headlight.
