Farmall H crack in haed
Anonymous-0
While cleaning the head of my H, I found a small crack on the underside if the head between two ports in the middle. What problems would this cause and should I be looking for a new head. The tractor would always start right up. One day it acted like it ran out of gas. Found very low compression, would only get gas to one cylinder. Rings appeared newer, no cracked or broken ones.
Between 2 ports as in the valves?? If yes yep you need to replace that head since a crack there can lead to water in the oil and other bad thing
The crack is actually between the two inner water ports, I guess you would call it. Only connecting the two ports, not going outward to the side only inwards, if that makes any sense.
If you decide you need to replace that head, we have a reconditioned head on the shelf for an H. Been resurfaced and pressure tested, 920 295 3278, Dale
