ivy
New User
my massy to35 it idles but it like it floods out when you throttle up and cuts out. had a carb kit put in new coil and plugs and points clean carb again set jets still does the same thing .
can we assume you checked spark and it is good, and the advance is working correctly? / timed correctly?
and when setting with fuel valve open it does not overflow into carb air hose?
