fuel gauge wiring directions for Ford Jubilee tractor
Anonymous-0
My Ford Jubilee tractor needs new gauge wired into
fuel system. Don't have directions or schematic
diagram. Would appreciate drawing of diagram to
follow. Can you help?
Since it didn't have a factory fuel gauge, it would be best to use your new gauge manufacturer's information. All gauges/senders are not identical.
ditto what Jmor said. naa were 52-54 production years. wasn't until the 01 seris in late 57 that fuel gauges came out..e tc. use your equipments direction. ( ps. a 641 will look like a naa with subtle but deffinate mechanical and not to mention cosmetic differences )
Bum a paint stick from the hardware store.Dosent have to be marked.If you see under 1 inch you may walk home.If you insist you can get a gas cap that reads gas level.You would have to cut into the tank for the sender.I just check the gas level with a paint stick before I use my tractor.
