Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: belly pump on
notjustair
06-16-2013 11:18:53
Do you have more fluid in it than you did? I'm thinking you may have hooked onto an implement with a cylinder extended, thus adding hydraulic to your system. Is that possible?
My Farmall M is my loader tractor - it has a live pump and uses the belly pump for storage. I didn't have enough fluid to have the loader up and use hydraulics on implements. I ended up hooking a hose to the fill and running that to a tank I mounted on the frame rail. That pump isn't very big for holding much fluid. With the amount that a live pump can put out I had lots of random puking going on until I added that tank for expansion room.
deerjack
06-16-2013 19:40:44
 Re: belly pump on in reply to notjustair, 06-16-2013 11:18:53
Hey notjustair, that could be my problem, i"ll check that out. When your system was puking out the oil was it coming up thru the fill tube like mine is? Thanks for the suggestion, much appreciated.--Jack
