TractorLinks.com
Restoration & Repair Tips Board
Re: JD 4040 low oil pressure, and steam/smoke from oil fill cap
buickanddeere
06-15-2013 07:52:14
Change the coolant now with a HD diesel rated concentrate mixed with distilled, not tap water. Old antifreeze turns acidic when the corrosion inhibiter wears out. You don"t want to pay for sleeve replacements . The transmission oil is likely just as icky as the engine oil . Drain , change filter and refill with Hy-gard. Put a real pressure gauge on there and test the engine oil pressure. Old gauges do go out of calibration with age but do you feel lucky? The 4040 is a pretty decent little tractor. iirc it has a Dubuque engine in a Waterloo chassis. I know it costs $$$ but save yourself $$$ in the long run by purchasing the operator"s and service manual. 1-800-522-7448. The parts manual is online at the JD web site.
Farmer1715
06-15-2013 20:00:25
 Re: JD 4040 low oil pressure, and steam/smoke from oil fill cap in reply to buickanddeere, 06-15-2013 07:52:14
ok thanks for the advice,
Mike Aylward
06-15-2013 12:35:54
Glen, the domestic 4040 always had a Waterloo 404 engine in it. It's basically just a detuned 4230. Mike
buickanddeere
06-15-2013 17:31:08
 Re: JD 4040 low oil pressure, and steam/smoke from oil fill cap in reply to Mike Aylward, 06-15-2013 12:35:54
I was thinking of the 4030, sorry.
