Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: alternator wiring
05-04-2013 13:38:37
Does it have a small plug on the side of the alternator with a #1 and #2 in it?? Is that open or covered up?? If open the #2 wire goes to the charge post on the alternator then 10 gauge wire from the big post goes to the amp gauge and you need to switch the wires on that gauge since it has to be - ground. Then the #1 wire with say a radio shack 276-1661 diode in line goes to the ignition switch side that is hot when turned on or you can go to the ignition side of the coil and do the same thing. The silver line on that diode goes towards the alternaotr
