Upper counter shaft seal
Zimbo711
New User
Hi All - I just got done replacing the counter shaft seal lower which connects to the belly pump on my Farmall H. While I"m in there i would like to replace the oil seal on the upper shaft but if possible I"d like to do it without dropping the belly pump.. Can anyone give me the details on how to do this? Thanks...
(quoted from post at 12:48:33 04/24/13) Hi All - I just got done replacing the counter shaft seal lower which connects to the belly pump on my Farmall H. While I"m in there i would like to replace the oil seal on the upper shaft but if possible I"d like to do it without dropping the belly pump.. Can anyone give me the details on how to do this? Thanks...
The belly pump HAS to come out because the driveshaft ALSO has to come out.
