Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: Fires but won't run
04-04-2013 20:01:56
i'm having the same type of problem. carb boiled out /bead blasted new kit / new plugs, cap rotor wires. runs misses then dies starts back up may back fire. .triple checked firing order i took carb apart couple times to double check.getting gas new wires i'm not happy with had to cut to fit. . i think it must be in ignition not sure 1966 case 930 took off valve covers rockets etc working . compression test was good 158 lbs +/- each cyl.. it's driving me nuts. thanks in advance john
04-05-2013 21:18:46
 Re: Fires but won't run in reply to axe55, 04-04-2013 20:01:56
I have found the problem. I wire from the ammeter to the starter button had a very bad connection. Got it replaced and she runs like a top now. At least I know my carb is cleaned!
