Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Fires but won't run
49erH
03-31-2013 17:00:13
I recently switched my tractor over to 12 volt I don"t know if that is the problem or not. After my conversion I had my tractor running for probably two weeks and the last time I parked it it wouldn"t start this morning. It fires for about a second or two but then shuts off. I have spark to my points and to my plugs. I have a new condensor on it. I do have gas getting into my carb. I took my carb off and apart and I ordered a rebuild kit for it. Didn"t know if anyone else had this problem and could help me out. Thanks
axe55
04-04-2013 20:01:56
 Re: Fires but won't run in reply to 49erH, 03-31-2013 17:00:13
i'm having the same type of problem. carb boiled out /bead blasted new kit / new plugs, cap rotor wires. runs misses then dies starts back up may back fire. .triple checked firing order i took carb apart couple times to double check.getting gas new wires i'm not happy with had to cut to fit. . i think it must be in ignition not sure 1966 case 930 took off valve covers rockets etc working . compression test was good 158 lbs +/- each cyl.. it's driving me nuts. thanks in advance john
49erH
04-05-2013 21:18:46
 Re: Fires but won't run in reply to axe55, 04-04-2013 20:01:56
I have found the problem. I wire from the ammeter to the starter button had a very bad connection. Got it replaced and she runs like a top now. At least I know my carb is cleaned!
El Toro
04-04-2013 04:08:30
Are you using a ballast resistor? Hal
49erH
04-04-2013 17:21:45
 Re: Fires but won't run in reply to El Toro, 04-04-2013 04:08:30
No I'm not because the 12 volt coil said not to.
Oliver662011
04-03-2013 18:02:58
 Re: Fires but won't run in reply to Jon Hagen, 03-31-2013 17:00:13
Also think about replacing the bakelite insulator on your distributor cap.
Mike
Oliver662011
04-03-2013 15:34:58
Replace condenser if you haven't since it started acting up, even if it was just put on there before the problem happened.
Mike
49erH
04-03-2013 17:28:21
 Re: Fires but won't run in reply to Oliver662011, 04-03-2013 15:34:58
I just put the condensor on it after it started acting up. Thought that was the problem.
C.R.
04-05-2013 02:53:01
 Re: Fires but won't run in reply to 49erH, 04-03-2013 17:28:21
sometimes you get a bad one try a different one
forty40
04-01-2013 12:03:27
99.9% of engines that won't fire or stay lit have an ignition problem.
6V systems do not require an ignition resistor since the coil is designed for 6 volts. If a 6 volt system is converted to 12 volts and nothing else changed, it will not take too long before the coil and/or points and condenser burn out from too high voltage. An engine may fire when first cranked but will not remain running due to one of the components being burned out.
When converting from 6V to 12V, either a ballast resistor needs to be wired in series in the primary coil circuit or a 12V coil with integral resistance needs to be installed.
If a ballast resistor or 12V coil has already been installed, and the problem has now cropped up, trouble shooting via the internet would only be a guess.
soundguy
04-04-2013 16:57:30
 Re: Fires but won't run in reply to forty40, 04-01-2013 12:03:27
as a 'genera' statement, saying 6v systems do not require resistors, is incorrect.
ford 9n, 2n, and 8n using a front mount distribuitor are 6v oem, and have a coil AND ballast resistor.
just sayin...
49erH
04-01-2013 17:53:40
I put a 12 volt coil on it and on he side of the coil it says do not use with external resistor.
C.R.
04-01-2013 02:36:36
saw one that did that and it had a wire broken off by the ballast resistor it would fire in the start position but quit when you would let the key go back to run
husker44a
03-31-2013 18:32:05
What is it on???
49erH
03-31-2013 18:38:00
 Re: Fires but won't run in reply to husker44a, 03-31-2013 18:32:05
1949 farmall h. Probably shoulda mentioned that.
