TractorLinks.com
Restoration & Repair Tips Board
Re: Noisey hydraulic valve
BFO
03-31-2013 06:22:22
Sounds like the weight of the loader is causing the relief valve to crack open, that"s what the high pitch squeal is. There should be a set screw with a locknut on the valve. Turn that screw clockwise until the noise stops. You will have to do it again when lifting a load. I would take i apart and inspect it, and replace if necessary. HTH
Stevewatr
03-31-2013 06:29:45
 Re: Noisey hydraulic valve in reply to BFO, 03-31-2013 06:22:22
Sounds like the right idea. I will take it out and inspect it before attempting adjustment, and report back.
Happy Easter.
Steve.
