Noisey hydraulic valve
Stevewatr
Hi, been working on my Oliver 770, came across an issue, thought I'd post symptoms, and get some thoughts.
tractor is fitted with a Ware loader/backhoe.
I changed the fluid in the resovoir, and the filter (return line type).
Fluid was milky, and filter was really nasty.
With fluid topped off, symptoms are as follows:
No unsual noise when running, and all spool valves in neutral.
When raising loader, a terrible noise comes from the loader valve, sort of a low pitched screech, and the loader seems slow to me. I say seems slow because this machine is new to me.
Lowering loader makes no noise, and I have enough down pressure to raise front end off the ground.
Backhoe swing cylinders, and boom work fine, and stabilizers can raise rear of tractor quickly, no strange noises, so I figure pump pressure is ok.
dipper stick cylinder is very slow, but no strange noise, so I think that's just a worn piston seal. Backhoe bucket cylinder has a bad leak, so I am not testing that for now.
Based on the above, anybody have any thoughts?
Thanks,
Steve.
Sounds like the weight of the loader is causing the relief valve to crack open, that"s what the high pitch squeal is. There should be a set screw with a locknut on the valve. Turn that screw clockwise until the noise stops. You will have to do it again when lifting a load. I would take i apart and inspect it, and replace if necessary. HTH
(quoted from post at 14:22:22 03/31/13) Sounds like the weight of the loader is causing the relief valve to crack open, that"s what the high pitch squeal is. There should be a set screw with a locknut on the valve. Turn that screw clockwise until the noise stops. You will have to do it again when lifting a load. I would take i apart and inspect it, and replace if necessary. HTH
Sounds like the right idea. I will take it out and inspect it before attempting adjustment, and report back.
Happy Easter.
Steve.
