Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
aftermarket bucket cylinder
Bob Hartle
03-28-2013 11:59:23
Anybody know where I can find a bucket lift cylinder for my model 2050 international loader. Took it to get seals put in it and they say the shaft is bent. Dealer says the whole cylinder or the shaft are no longer available. Can anybody help?
schriffs
04-03-2013 19:18:08
 Re: aftermarket bucket cylinder in reply to Bob Hartle, 03-28-2013 11:59:23
I don't know your location, but we've had Mid-states Hydraulic (Alexandria, MN) make cylinders and parts for us at work. Not sure what kind of cost, but we keep going back...
www.mid-stateshydraulic.com
This post was edited by schriffs at 19:18:41 04/03/13.
KCTractors
03-29-2013 15:34:17
Try WWW.DaltonHydraulic.com
Bob Hartle
03-29-2013 17:42:10
 Re: aftermarket bucket cylinder in reply to KCTractors, 03-29-2013 15:34:17
Would a cylinder with the overall extended lenght fit? As long as the bore and rod are the same size?
showcrop
03-28-2013 18:09:29
Third on a good shop will fix it.
Bob Hartle
03-29-2013 02:21:17
 Re: aftermarket bucket cylinder in reply to showcrop, 03-28-2013 18:09:29
The guy at the shop told me he could make it. The cost is over $500.00. That why I was interested in a after market replacement.
Rufus80
03-29-2013 11:10:18
 Re: aftermarket bucket cylinder in reply to Bob Hartle, 03-29-2013 02:21:17
Look for a different shop, $500 is excessive for a new rod and seals.
Stick welding
03-28-2013 15:25:31
If the shaft isn't bent too bad, a good hyd. or machine shop can straighten it. If it needs replacing, the shop could make you a new shaft.
danmcdonald
03-28-2013 14:05:50
A good cylinder shop can make new shafts.
rrlund
03-28-2013 12:24:05
I've always been able to match something up with a "will fit" from Northern Tool on things like that.
Bob Hartle
03-31-2013 11:12:59
 Re: aftermarket bucket cylinder in reply to rrlund, 03-28-2013 12:24:05
I found a after market close to what I need but its only rated at 2500 psi. Will that work?
Stick welding
03-31-2013 12:10:42
 Re: aftermarket bucket cylinder in reply to Bob Hartle, 03-31-2013 11:12:59
Close only counts in horseshoes and hand grenades. LoL Both bucket cylinders need to be the same or one cylinder will get pounded at the end of the stroke or twist your bucket. I agree to look for another shop to make a new shaft if the old one can't be straightened. If it wasn't instantly noticeable the shaft was bent, it can probably be straightened in a press using V blocks and a dial indicator. A machine shop could do this for you and it shouldn't cost very much at all.
Copyright © 1997-2015 Yesterday's Tractor Co.
