HELP NEEDED I’m wiring a voltage regulator on a 1961 MF 35 with 3 cylinder Perkins. The diagram on this site with control box not helpful. Like the original, the replacement regulator I’m installing has a “F” terminal, a “BAT” terminal, a “L” terminal, and a terminal on the bottom unlabeled, but same terminal on the one removed was stamped 4M, 12V, P/N. The “F” and bottom terminals (4M, 12V, P/N), were wired to the Dynamo. The “BAT” terminal I believe was headed toward the instrument cluster, and the “L” terminal was not connected at all. Having problem finding wiring diagram. Can anyone tell me how to wire this voltage regulator.
Desperate,
Phil
Desperate,
Phil
