TractorLinks.com
Restoration & Repair Tips Board
Re: cleaning gas tank
Stephen Newell
03-10-2013 05:18:14
If the tank is diesel I would start with diesel tank cleaning solution. If gas I would just wash it out with muratic acid, force dry and then coat the inside with Red Kote fuel tank liner.
Stephen Newell
03-10-2013 05:23:44
 Re: cleaning gas tank in reply to Stephen Newell, 03-10-2013 05:18:14
Missed a step. After washing out with muratic acid thoroughly rinse the tank with water and then force dry.
Dave Sherburne NY
03-10-2013 19:48:49
 Re: cleaning gas tank in reply to Stephen Newell, 03-10-2013 05:23:44
I cleaned one on my 29 Essex just the way Stephen said. Make sure you do it outside the fumes will knock you over. Make sure it's really dry before You put the RedKote in it.
Nebraska Kirk
03-10-2013 17:18:09
I rinse the tank twice with a little acetone after rinsing with water. The acetone absorbs water.
Stephen Newell
03-11-2013 07:13:18
 Re: cleaning gas tank in reply to Nebraska Kirk, 03-10-2013 17:18:09
Dentured alcohol would work better than acetone. I just used a heat gun on mine.
