| Author |
[Modern View]
| Oliver662011
03-04-2013 16:39:27
199.218.126.91
I am restoring a JD Model 52 two bottom plow on steel. Every single bolt is trashed and nearly rotted in half. The person I am restoring it for requested we replace with more Square head bolts. I contacted Fastenal however grade 5 5/8" 4inch in length are nearly 16 bucks each, through fastenal I am looking at almost 700 dollars for just bolts! No nuts or washers. :evil: I am wondering if anyone has other ideas on where I can get a good square bolts ranging in length mainly 1/2 or 5/8 in diameter. Or if they have a bunch they are willing to sell. If I do have to buy them at that price it will break my budget, also I wanted grade 8 but they are 30 bucks a piece. Do you think grade 5 will be good enough for the frame bolts and stuff if I do have to resort to buying them? Thanks for all your help.
Mike |
| Bob
03-08-2013 20:41:20
64.255.159.192
Re: Looking for Square Bolts! Please Help in reply to Oliver662011, 03-04-2013 16:39:27
| You never thought of the Deere dealer, did you? 5/8" X 4 square head bolts are readily available there for about $3.37 each, depending upon each dealer"s price! They are even Grade 8! If you go to jdparts.com and search "By Part Specifications" they have quite a variety of square-head bolts still available.If you look in the Parts Catalog (updated in "63) for the plow, they show hex fasteners. |
| Oliver662011
03-05-2013 15:11:32
98.31.23.236
| Thanks for all the help guys, I either probably going with Norm, or Blacksmith Bolt, still waiting for a price call back from Norm.
Thanks again,
Mike |
| 55 50 Ron
03-05-2013 14:39:30
209.131.224.88
| | McMaster Carr lists 60,000 tensile strength bolts as Grade A. That must be a change as 60,000 used to be the Grade 2 spec. That should sure be enough for your plow bolts. |
| Dick L
03-05-2013 13:38:25
50.51.144.0
| | Try Production Tool . Several years back I bought several boxes of square head bolts and nuts. They didn't have them cataloged at the time but my sales person ordered them for me. I had to take full boxes because they wouldn't stock them at the time anyway. I still have some of the smaller bolts but the larger bolts had fewer in a box and I didn't get a lot more than I needed for what I was doing. They were a little more expensive but not all that much or I wouldn't have popped for them. |
| Dick L
03-05-2013 13:48:22
50.51.144.0
Re: Looking for Square Bolts! Please Help in reply to Dick L, 03-05-2013 13:38:25
| It doesn't look like Production took has bolts on line. |
| Stephen Newell
03-05-2013 05:09:46
66.53.83.42
| You might have to tell the client that there would be an additional charge for square head bolts and explain why. They will have a different appearance anyway as the heads will be physically thinner. |
| nys
03-05-2013 02:15:04
98.15.254.212
| Graham from New Zealand
03-05-2013 03:32:34
58.96.55.23
Re: Looking for Square Bolts! Please Help in reply to nys, 03-05-2013 02:15:04
| Do you mean plough bolts? Try a carriage bolt through the hole and heat the head red hot and hammer into the counter sink |
| AG in IN
03-04-2013 19:43:08
67.237.22.143
| Maybe this guy can help:
Norm Jackson
(317)-431-4803
He always has square-headed hardware at IH tractor shows.
AG |
| Oliver662011
03-04-2013 19:33:09
98.31.23.236
Re: Looking for Square Bolts! Please Help in reply to old, 03-04-2013 16:39:27
| Quoting Removed, click Modern View to see
In heavy yellow clay does it matter? It isn't mine but I figure he will probably do one or two acres, but its like I said HEAVY. It would help my budget if I used twos but I want to be sure it wont rip apart. Thanks for all your help guys. |
| fixerupper
03-05-2013 13:01:34
216.16.92.221
Re: Looking for Square Bolts! Please Help in reply to Oliver662011, 03-04-2013 19:33:09
| Did they even have grade 5 back in the day? I'll betcha the factory bolts are 2's. Jim |
| Nebraska Kirk
03-04-2013 19:17:56
207.91.4.159
| Grade 5 is overkill for a plow that will get very little use. Grade 2 will work just fine. |
| patsdeere
03-04-2013 18:02:08
50.156.47.162
| | Have you tried mcmaster carr? They have 1/2"x5" for 6.90. Granted they are only grade 5, but it says they are min tensile of 120K psi. Also look for a fastener store. I have one in my area that I can get 2 of this and 4 of that. |
| hintocw
03-28-2013 09:41:49
184.4.96.172
Re: Looking for Square Bolts! Please Help in reply to patsdeere, 03-04-2013 18:02:08
| I'm able to obtain all the square head fasteners (bolts) at the local Lowes store (can probably find the same at the Home Depot). |
