I posted a message earlier and haven"t got a response. I"ll try again with a little more detail. I aquired a International t340 crawler. It Steers to the left fine but not to the right. It will steer to the right if you pull real hard on the stick. I restore tractors as a hobby. I figure its the brake worn out. I"ve got the track and rear sprocket off. I"ve got it the tractor unbolted from the frame, so I can jack the tractor up and get the final drive off. All the bolts that hold the final drive to the transmission are out, but I Can"t get it off.
It want budge. Is there something holding it internally to the axle shaft? I"m Stumped.
