Timing marks
Gary Bailey
New User
I am rebuilding the motor in my 8N Tractor. I have the timing marks on the cam and on the crank lined up, intake valve closed but #1 cylinder is not all the way up. Is this normal, for timing?
Considering most vehicles are timed at tip dead center. Need reply asap.
Thank you
On those engines, when the timing gear marks are lined up, #1 is NOT @ TDC. The marks correlate the relative positions of the crank and cam and do NOT indicate #1 TDC.
You are "good to go"!
