Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: International Harvester 444
John B.
02-28-2013 12:09:09
May be a heavy float inside the carb. Does it smoke? I would take a compression check on all the cylinders, it sounds like your compression is low. I've done it and have seen many people pull the carb apart thinking the problem is in there when the compression is really the problem. An old timer once told me 40 years ago, never do a tune-up on an engine until you check the compression first.
An engine needs 4 things to run,
1. Fuel
2. Air
3. Compression
4. Ignition
Frank Castro
02-28-2013 14:48:23
 Re: International Harvester 444 in reply to John B., 02-28-2013 12:09:09
Thanks for the info. I will do a compression test this weekend if it warms up. I will also empty the carb via screw at bottom of carb and see if that helps. Do you know the compression value I should be looking for? I have a manual somewhere but it would take a while for me to find it. Also, Is there a way to check the float? Thanks so much for your help. I greatly appreciate it.
Copyright © 1997-2015 Yesterday's Tractor Co.
