Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: John Deere 1010 won't start when hot
bmfudge
02-19-2013 19:16:32
Thanks all for the replies! I'm thinking there may be an issue with the carb. I found that if I run the tractor at all and shut it off, it won't start agian - unless it sits for awhile. Doesn't mater if it's warm or not. I saw in another posting that the carb could flood the cylinders with gas afterward it's shut off. i got the tractor running and then shut the gas off and let the tractor stop on it's own. Once it did, I turned the gas on and tried to start it - and it started right up. Any ideas on what I could have done wrong on the carb? Its a TSX-860.
Thanks!
old
02-20-2013 11:29:30
 Re: John Deere 1010 won't start when hot in reply to bmfudge, 02-19-2013 19:16:32
Couple things come to mind. #1 float set wrong. #2 if you replaced the needle seat and the needle the seat may not be tight enough. #3 the needle you put in has the rubber tip and if it does it takes time for it the get a set in the rubber so it seals like it should. I always preset the needle by setting it in the seat and then tapping on it a few times with a screwdriver handle etc.
