Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: Re: front loader hook up
[Show Entire Topic]  [Return to Forum]
JMS./MN
02-19-2013 18:49:02
209.237.125.241
Two possibilities. Remote hyd SCV hookup(s). With a loader needing one circuit, can plug into one SCV. All hyd loader, you need two remote SCV valves. Or, in front of the brake pedals, there is a 90 degree fitting, sending oil to the rockshaft on the rear of the tractor. Replace the 90 with a Tee fitting, and run a line from the Tee to a hyd valve for the loader. Then you need an oil return line from the valve, to the tractor hyd oil sump. That can be done by buying a ported cover for the transmission filter, and running the return line to that cover.
[Reply]   [No Email]
buickanddeere
02-20-2013 11:54:34
184.151.63.252
 Re: front loader hook up in reply to JMS./MN, 02-19-2013 18:49:02
Do not return oil to sump. The transmission pump is much too small to supply the front pump.
Oil must be returned to the point between the trans pump discharge and the dirty side of the hydraulic filter.
That is either via a ported filter cover, a power beyond block connection or "T" into the rockshaft return line.
[Reply]  [No Email]
rrlund
02-20-2013 15:46:41
207.241.137.116
 Re: front loader hook up in reply to buickanddeere, 02-20-2013 11:54:34
Why do they make a filter cup that threaded for that purpose then?
[Reply]  [No Email]
Cliff Nelson
02-23-2013 16:36:05
69.21.97.161
 Re: front loader hook up in reply to rrlund, 02-20-2013 15:46:41
The filter cover is returning oil to the return system after the trans pump which is where it needs to go. JMS was right in returning oil to the filter cover but wrong in calling it the sump. Returning to sump will starve the main hyd pump for oil. Hope this helps.
[Reply]  [No Email]
rrlund
02-20-2013 07:17:44
207.241.137.116
The local Deere dealer used to just drill a hole in the filter cover and tap them to a half inch pipe thread. The one on my 1020 is drilled and tapped.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
