TractorLinks.com
Restoration & Repair Tips Board
Re: flashing my D-14
John B.
02-19-2013 18:25:40
Maybe you have a 12 volt light on a 6 volt system. Is this the problem possibly? If this is the first negative ground system you've put a light on it should work if the correct voltage. Negative ground system is today's common.
I would run a both wires to the battery thru a switch. If it only has one wire I would install a ground wire directly to the battery.
redjohn
02-20-2013 15:19:07
 Re: flashing my D-14 in reply to John B., 02-19-2013 18:25:40
The flasher is working fine now. The tractor either was or has been switched to 12 volts. Just looking at the battery would tell one that.
I'm afraid I may not have quite enough resistance on the flashing light system though, because after sitting outside for a day, when I turn the flasher on, it takes a good 30 seconds or so, before it starts flashing.
