| Restoration & Repair Tips Board |
Topic: Belly pump removal on a Farmall M
[Return to Forum]
| Author |
[Modern View]
| engine 2
02-18-2013 16:43:11
166.181.3.217
Dose the pump just angle out when you remove the four bolts on the bottom? |
| John B.
02-19-2013 18:33:40
38.114.64.177
Re: Belly pump removal on a Farmall M in reply to engine 2, 02-18-2013 16:43:11
| The coupler isn't that hard to put in you just have to have patience. I have mounted it on the pump before I lift it all the way up in there. You may have to manually crank the engine over slowly to rotate the drive shaft for the pump to get the slot in the vertical position. |
| John B.
02-19-2013 18:27:26
38.114.64.177
| There is a hole in the bottom of the belly pump that runs all the way thru from one side to the other. That is to put a rod thru and a man on each side to lower it. Removing the bolts and installing long all thread is a lot safer thought. |
| flambeauone
02-18-2013 16:59:33
66.87.102.78
| You have to remove all of the fittings in the sides, remove the cap for the dipstick, remove the valve handle, then turn the coupling so one side is vertical. Then unbolt while its supported and lower with a floor jack while balancing it. I done it last time by removing two bolts and threading all thread in with nuts on it to lower it because I didnt have anyone to hold it steady on a floor jack. Be careful its kinda heavy. |
| flambeauone
02-18-2013 17:31:23
66.87.102.78
Re: Belly pump removal on a Farmall M in reply to flambeauone, 02-18-2013 16:59:33
| I should have described the coupler in more detail. Its a piece of round stock with two keys machined in it. One on each end and ninety degrees from one another. Google farmall m belly pump coupler pics for an image. One key has to be vertical doesnt matter which one. |
| charlie M
02-18-2013 17:12:01
74.34.216.81
| You also have to have the coupling lined up for the 2 pieces to slide apart. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
