| Restoration & Repair Tips Board |
Topic: John Deere 1010 won't start when hot
[Return to Forum]
| Author |
[Modern View]
| bmfudge
02-18-2013 14:13:55
107.200.120.108
Hi All,
I have a '64 John Deere 1010. It starts rough but then seems to run ok once it warms up. I've replaced the coil, plug wires, distributor and rotor. I put in an electronic Ingition and rebuit the carb too. if I run it for awhile and shut it off, then it won't start - even with startign fluid. After it cools down for an hour or so, it start righ up. I'm at a loss - any thought would be helpfull.
Thanks |
| bmfudge
02-19-2013 19:16:32
107.200.120.108
Re: John Deere 1010 won't start when hot in reply to bmfudge, 02-18-2013 14:13:55
| Thanks all for the replies! I'm thinking there may be an issue with the carb. I found that if I run the tractor at all and shut it off, it won't start agian - unless it sits for awhile. Doesn't mater if it's warm or not. I saw in another posting that the carb could flood the cylinders with gas afterward it's shut off. i got the tractor running and then shut the gas off and let the tractor stop on it's own. Once it did, I turned the gas on and tried to start it - and it started right up. Any ideas on what I could have done wrong on the carb? Its a TSX-860.
Thanks! |
| old
02-20-2013 11:29:30
209.86.226.11
Re: John Deere 1010 won't start when hot in reply to bmfudge, 02-19-2013 19:16:32
| Couple things come to mind. #1 float set wrong. #2 if you replaced the needle seat and the needle the seat may not be tight enough. #3 the needle you put in has the rubber tip and if it does it takes time for it the get a set in the rubber so it seals like it should. I always preset the needle by setting it in the seat and then tapping on it a few times with a screwdriver handle etc. |
| Ray Mitchler
02-19-2013 12:29:33
108.180.45.28
| I would take out the electronic ignition and put a new set of points and condensor back in. |
| greygoat
02-19-2013 08:02:54
69.179.12.50
| I know nothing about John Deere's..but I do know that when a magneto equipped engine won't start when hot, it can be a coil going bad. |
| rrlund
02-19-2013 07:08:51
207.241.137.116
| Just thinking out loud here. How's the rocker clearance? Have you had the tapped cover off? I'm just wondering if you've got some valves that just aren't quite closing,causing low compression and low vacuum so it isn't pulling the gas up from the carb like it should? |
| MisterT
02-19-2013 07:52:39
216.248.71.226
Re: John Deere 1010 won't start when hot in reply to rrlund, 02-19-2013 07:08:51
| Quoting Removed, click Modern View to see
That was my first thought also. If the valves can't close, there will be very little compression. |
| buickanddeere
02-18-2013 17:36:03
209.240.116.36
| Plug gap? Are the plugs solid core such as an Autolite 3116? What is static timing at cranking rpm?If more than a couple of degrees before TDC, she will kick back. Stuck advance weights or over advanced initial timing are all too common. What is coil voltage while cranking? |
| old
02-18-2013 15:12:53
209.86.226.19
| Check your spark before you start it and then check it again when it gives you problems. Spark at all 4 plugs needs to be a blue/white and jump a 1/4 inch gap or more. Also when was the last time you serviced the air cleaner it maybe full of water and dirt |
| El Toro
02-18-2013 14:37:56
108.3.143.30
| It may be your electronic ignition when it gets hot. Hal |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
