Bearing and oil seal for the bull pinion shaft?
Anonymous-0
I'm looking for some good bearings and oil seals
for the right and left side bull pinion shafts in
my Farmall 400.
I've not had a lot of luck on line getting any
part numbers and don't want to get the wrong parts
or parts that won't last.
There seems to be automotive and what I'm guessing
are industrial heavy duty bearings and seals?
I did see a Timken 450316 seal and a 1213A bearing
that looks to be updated parts but like I said I'm
really not sure.
If anyone could help me out on this I'd really
appreciate it.
thanks
(quoted from post at 21:05:16 02/16/13) bearings and oil seals for the right and left side bull pinion shafts in
my Farmall 400.
Info is easy enough to find on-line.
Use FIAT parts lookup:
http://partstore.caseih.com/us/parts-search.html#epc::mr56558ar957886
to get the IH part numbers, then use
http://www.skf.com/binary/12-66347/457013.pdf
to cross the bearings to industry numbers, and
http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
to cross the seal numbers. After all this, I wonder how much cheaper you can find them than simply having the dealer get them?
Thanks Bob for the information, but somehow the
info. and exploded diagram in link you sent was lost
on the CaseIH site when I clicked on "find a dealer"
when I back clicked it went back to the same page
with a different layout, I don't know what happened,
and from what I see the Farmall 400 is not listed on
the CaseIH site only newer models.
Go to:
Click "Parts Catalog" at the left.
Then, click "Find by model".
Then click "Search".
A box will open "Search by model".
Enter "400".
Hit "Search".
A list will come up, including IH 400 gas or IH 400 diesel.
Click on the one you have.
The final drive breakdowns are in the "Chassis" section.
