Run tractor before painting
mmfun
Working on a Moline have the engine all torn down and cleaned going back together with it. Need to switch out the rear axle housing sometime but not right now. Was woundering if there is a primer I could put down on the engine to protect it until I get the rear housing changed and then paint the tractor all at one time. Any input would be helpful.
Use a good primer/sealer to keep it from rusting. I like to have spray cans of the right color when assembling to paint blind spots (between blocks, etc). Makes painting easier if the tight spots have color already.
