TractorLinks.com
Restoration & Repair Tips Board
Re: MM water pump
old
01-20-2013 08:47:18
Thermostat should be some place in line with the top radiator hose. You could also have a block that is full of rust and lime and needs to be flushed. My self I use white vinegar. Drain the system and fill with vinegar and run it till hot. Let cool and drain then flush with water from a garden hose. Best way is to rig up a way to use the block drain to flush it
Mendontractor guy
01-20-2013 09:03:03
 Re: MM water pump in reply to old, 01-20-2013 08:47:18
Thanks for the advice. hope to have time tonight to look for that thermostat and will do the flush as you suggest!
Jon Hagen
01-20-2013 20:04:20
 Re: MM water pump in reply to Mendontractor guy, 01-20-2013 09:03:03
Some moline models had a thermostat cartridge inside the top radiator hose. A seemingly unnessary hose clamp in the middle of the hose and a hard spot in the hose is a tipoff.
I also agree to look for a stuck distributor advance or retarded ign timing.
Have also seen overheating from a bad water pump seal leaking air into the system.
