Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: MM water pump
old
01-19-2013 18:22:26
Lack of a thermostat will in fact cause over heating due to the fact the water flows to fast to cool down do it keep getting hotter instead of having time to cool down.
Mendontractorguy
01-20-2013 05:54:47
 Re: MM water pump in reply to old, 01-19-2013 18:22:26
hen I said 'No Thermostat" I meant I don't see one or anyplace one would have been. This tractor ran fine until just after I bought it from a friend.
old
01-20-2013 08:47:18
 Re: MM water pump in reply to Mendontractorguy, 01-20-2013 05:54:47
Thermostat should be some place in line with the top radiator hose. You could also have a block that is full of rust and lime and needs to be flushed. My self I use white vinegar. Drain the system and fill with vinegar and run it till hot. Let cool and drain then flush with water from a garden hose. Best way is to rig up a way to use the block drain to flush it
Mendontractor guy
01-20-2013 09:03:03
 Re: MM water pump in reply to old, 01-20-2013 08:47:18
Thanks for the advice. hope to have time tonight to look for that thermostat and will do the flush as you suggest!
Jon Hagen
01-20-2013 20:04:20
 Re: MM water pump in reply to Mendontractor guy, 01-20-2013 09:03:03
Some moline models had a thermostat cartridge inside the top radiator hose. A seemingly unnessary hose clamp in the middle of the hose and a hard spot in the hose is a tipoff.
I also agree to look for a stuck distributor advance or retarded ign timing.
Have also seen overheating from a bad water pump seal leaking air into the system.
