Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: Re: Farmall cub engine
[Show Entire Topic]  [Return to Forum]
CDrake
01-19-2013 08:45:46
108.45.60.34
Have done as suggested; took carb apart, soaked in 1 gal bucket container of carb cleaner (from Advance Auto) for approx. 24 hours, then cleaned it with spray carb cleaner, blew it out with compressed air,reassembled all, and re-installed carb.
Intially, it seemed that this had improved things; I fiddled with the two adjustment screws. Then ,it started to hunt again, exactly as before.
BTW, I have also sprayed about half a can of PB Blaster on the near pivot to the governor (as well as the far pivot, near the throddle linkage).
Where should I go now?
[Reply]   [No Email]
showcrop
01-19-2013 10:32:30
75.67.231.80
As I posted before, The common problem with governor linkage is not need of PB blaster, but the opposite. The holes and connections get overly loose and the spring can get slack. Your owner's manual should give you instructions on adjustment but here it is very basically: Disconnect the rod from the governor arm to the carb, open throttle butterfly fully, set the throttle to full, position the rod end next to the throttle arm of the carb. The rod from the governor to the carb should be in the exact position to slip together. If not, you need to adjust the length of the rod to where they will slip together.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
