TractorLinks.com
Restoration & Repair Tips Board
Re: Farmall cub engine "lopes"
CDrake
01-13-2013 13:58:03
Thanks to both who have responded. I drained the main jet; no change.
Have liberally applied PB blaster to the pivot on top of the governor; it moves much more freely, but still hunts, off and on ,while I am driving, pushing (has a plow), of just standing still.
As mentioned, I will keep putting the blaster on that pivot, as other far pivot is OK. Can't see where else you could free up binding. If this doesn't work after a few days, what is next step? Governor disassembly?
Just read last post; got me to wondering about that carb; didn't really adjust anything during the rebuilt (basically just replaced gaskets and needle valve,etc.).
Wonder about the wisdom of attempting to resusitate a (50-60 YO) carb.
Futzed around with a Weber 2 barrel on one of my Alfas for the longest time; finally just paid $200 for a new one, put it on, and presto, has run like gangbusters ever since. So, maybe a new IH carb is indicated?
Thoughts? (And cheapest place to get one!-looks like they run more than that DGV 36/32 that I got fro Peirce Manifold!)
This post was edited by CDrake at 14:07:40 01/13/13.
showcrop
01-13-2013 16:52:25
 Re: Farmall cub engine "lopes" in reply to CDrake, 01-13-2013 13:58:03
I have never encountered binding governor linkage, it has always been loose.
old
01-13-2013 16:01:46
 Re: Farmall cub engine in reply to CDrake, 01-13-2013 13:58:03
Bet you have some loose junk in the carb. Since the main jet sits low it can clog up easy form any small piece of dirt or rust. I would pull the carb drain plug out of the bottom and let fuel flow a couple minutes. Catch it so you can use it and also to look for dirt etc in it. Also did you use a small wire to poke out the little hole in the main jet?? If not then do so it can only help.
As for comparing a Weber carb on an Alfa to that car it would be like comparing a Model T to a Corvette. Years ago I had a 1967 Alra Roemor which had 2-2 barrel side draft Webers on it and boy was that a fast car
