Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: 1950 Farmall H seat pivot removal
wilsonsk
01-13-2013 12:26:09
I got it, I took the shock off and the bolt I could remove and could twist the seat enough to slide it off of the shaft sideways, then put a visegrip on the shaft and used the impact on the stuck bolt. It went slow the whole way, but came off finally. The pivot shaft is very rusted and eroded, I can reuse it if need be, but I think I'll make a new one at work.
MisterT
01-14-2013 07:03:31
 Re: 1950 Farmall H seat pivot removal in reply to wilsonsk, 01-13-2013 12:26:09
More often than not, that old pivot pin needs a hack saw taken to it. A pair of tapered shock absorber bushings, a length of 1/2" threaded rod, a couple of nuts and lockwashers, and you're back in business.
