TractorLinks.com
Restoration & Repair Tips Board
Re: Farmall cub engine "lopes"
showcrop
01-13-2013 12:12:42
Lopeing or more commonly called "hunting" is usually a symptom of a problem with the governor or linkage. Many governed motors will do it on first start up, then smooth out after a little warm up. Since the linkage is usually much easier to get at than the governor, it would be good to start out by checking governor linkage connections and correcting any that you find loose.
Bob
01-13-2013 13:56:57
 Re: Farmall cub engine in reply to showcrop, 01-13-2013 12:12:42
Not gonna argue with you, but in my experience, the most common cause of governor "hunting" is carburetor problems. The idle circuit and the load circuit both need to be operating properly and be adjusted correctly (as well as any "transfer passage"/circuit in the carb) or the engine will falter as it it comes up to governed speed and the governor backs off the throttle, then the governor will jerk the throttle back open, causing "hunting", which sounds EXACTLY like the problem he is having. Of course, governor or linkage wear pr maladjustment certainly is a possibility.
