Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: rocker arm's
old
12-29-2012 20:40:03
Very hard to help you help your self with out knowing what your working on. Lack of info means lack of or no help
f mcclain
12-30-2012 08:49:15
 Re: rocker arm's in reply to old, 12-29-2012 20:40:03
oops,
Excited to find the site and missed an important part huh. It is a 1953 golden jubilee.
old
12-30-2012 10:32:31
 Re: rocker arm's in reply to f mcclain, 12-30-2012 08:49:15
Yes as JMOR says. You say your blowing the oil filter gasket. Make sure you do not have an oil o-ring sticking in the base because that will cause that and if you do not then your oil pump relief valve maybe sticking or set to high either one of those will cause that problem
JMOR
12-30-2012 10:38:34
 Re: rocker arm's in reply to old, 12-30-2012 10:32:31
Where is the "rocker arm spurt hole" that you mentioned?
f mcclain
01-02-2013 16:02:06
 Re: rocker arm's in reply to JMOR, 12-30-2012 10:38:34
The spurt hole is on the top of the rocker arm,it's the hole in which the oil come's out of to lube the valve tip.The question is, on the inside of the rocker (rocker removed) you will see a center groove or channel for oil to flow through< look a little higher and and you will see it. Does the original rocker have a groove or channel connecting the center to the oil hole?
JMOR
01-02-2013 21:36:05
 Re: rocker arm's in reply to f mcclain, 01-02-2013 16:02:06
Quoting Removed, click Modern View to seeawhtx is going to look at some Fri or Sat. I just don't recognize the hole that you speak of, sorry.
old
12-30-2012 11:23:30
Looks like you posted to the wrong person LOL
JMOR
12-30-2012 11:25:49
 Re: rocker arm's in reply to old, 12-30-2012 11:23:30
Quoting Removed, click Modern View to seeIf he ever returns, he will figure it out. I typically just post onto the last entry on Modern View........messes up minds, I guess. :!:
old
12-30-2012 13:09:20
 Re: rocker arm's in reply to JMOR, 12-30-2012 11:25:49
Don't know how that is since I am on the classic side so do not know how modern even works
JMOR
12-30-2012 13:39:23
 Re: rocker arm's in reply to old, 12-30-2012 13:09:20
Quoting Removed, click Modern View to seeWhat I like about Modern is that latest postings always rise to top of list.
JMOR
12-30-2012 09:26:00
I recommend posting your question on the YT FORD forum & hope that AWHTX sees it.
Copyright © 1997-2015 Yesterday's Tractor Co.
