| Restoration & Repair Tips Board |
Topic: Farmall 460 engine issues???
[Return to Forum]
| Author |
[Modern View]
| Ryan Foster
12-26-2012 15:56:59
70.197.201.111
I'll get straight to my problem. My Farmall 460 idles fine, but when I put it into gear and drive for 300-500 yards (1/4 mile or so) or am working with the hydrolics (pushing snow) for only a little while the engine just dies. It smells of gas like its either getting too much or not enough (not sure which) I've pulled the fuel line and have a nice stream (not too fast, and not dripping slow). I've also used a carburetor cleaning kit and changed out everything it instructed. When the same problem was still present I then cleaned out the oil pan and pipes for the air cleaner. After that (problem still the same) I installed an additional fuel filter to make sure gas wasn't dirty. I have also replaced the choke cable and made new adjustments to the idle and inflow. I'm at a loss and looking for new ideas. It idles fine and can rev engine with no problems even after it dies. t its just after a short amount of use (in gear) when things go wrong. Any insight would be greatly appreciated!!! |
[Reply] [No Email] | |
| casecollectorsc
12-30-2012 14:59:34
75.102.173.136
Re: Farmall 460 engine issues??? in reply to Ryan Foster, 12-26-2012 15:56:59
| Don't know about 460, can you open the load needle 1/2 turn to see if it improves?? |
| El Toro
12-27-2012 04:42:21
108.3.143.30
| When the engine quits check the fire to your sparkplugs asap before the engine cools. Should see a hot blue spark. If you see a weak spark your coil may need replacing. Hal |
| Ryan Foster
12-26-2012 20:23:51
70.197.201.111
| Yes the new fuel filter was the one that was suggested from the expert at our local international farm shop. The flow of gas was a constant stream that maintained its flow until all the gas had drained. I'll definitely check the plugs. Not sure the last time they were changed, but our mechanic at work mentioned something about them. I'm not too knowledgeable with engines, but I must admit it has been fun getting to know the things I've already learned. Thank you to everyone for the ideas and please if there are any other suggestions keep them coming. Thanks in advance! |
| showcrop
12-27-2012 05:43:35
75.67.231.80
Re: Farmall 460 engine issues??? in reply to Ryan Foster, 12-26-2012 20:23:51
| Quoting Removed, click Modern View to see
"All the gas had drained" Does that mean from the tank or from the bowl? If it stopped after the bowl was empty it would not run for very long. |
| exyoungman
02-01-2013 19:37:15
12.202.137.107
Re: Farmall 460 engine issues??? in reply to showcrop, 12-27-2012 05:43:35
| check in the fuel tank I have had a dead bug float and cover the fuel line while it is running . when the engine stops the bug floats away and everything works fine until the bug plugs the line again |
| Jms2
12-26-2012 18:54:33
199.30.100.173
| How hot of spark plugs are you using? If you are running D21 plugs in a 6 cylinder that is to hot unless they burn alot of oil. I dont think this is a gas problem. We have fixed many 6 cylinders with the same problem. It is usually a scored cylinder. The proper fix for this is an overhaul. I have been a mechanic for 25 years so I have seen this very often. |
| showcrop
12-26-2012 17:21:59
75.67.231.80
| h
For how long does that nice stream of gas flow? |
| steve_in_mo
12-26-2012 17:01:26
205.240.41.69
| She's starving. Was that a small engine fuel filter? Make sure that fuel filter is meant for a gravity flow system and is rated to flow enough fuel for your tractor. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
