Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: Running a 12 volt hydraulic pump on 6 volts????
12-14-2012 07:20:44
Most older plow pumps draw between 150 and 200 amps so you need to be constantly charging the battery if your going to be really using that pump... A fully charged battery won't last too long if you have to lift and angle the plow more than a couple of times (trust me I've been there and done it).....
12-14-2012 07:31:29
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to chevytaHOE5674, 12-14-2012 07:20:44
Ya but still better then burning out the pump which a 6 volt battery would do over time. That said I have had more then one tractor with a bad charging system and I could run them for months on a battery before charging and I figure I got at least 10-15 engine starts before I had to recharge the battery
12-14-2012 11:49:50
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to old, 12-14-2012 07:31:29
Running the tractor and running a 200 amp plow pump are two different things. Drawing that kind of amperage out of a battery without charging it is a sure fire way to destroy a good battery in no time.....
12-14-2012 14:56:57
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to chevytaHOE5674, 12-14-2012 11:49:50
Wrong That is what a deep cycle battery is made to do and I have many times used a battery in just such as I said and have yet to destroy one
